翻墙不能用了 各位前辈帮助一下
翻墙不能用了 各位前辈帮助一下
原因就是下面的 谢谢
Fri Apr 03 21:57:06 2009 OpenVPN 2.1_rc4 Win32-MinGW [SSL] [LZO2] built on Apr 25 2007
Fri Apr 03 21:57:17 2009 Control Channel Authentication: using 'ta.key' as a OpenVPN static key file
Fri Apr 03 21:57:17 2009 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Apr 03 21:57:17 2009 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Apr 03 21:57:17 2009 LZO compression initialized
Fri Apr 03 21:57:17 2009 Control Channel MTU parms [ L:1542 D:166 EF:66 EB:0 ET:0 EL:0 ]
Fri Apr 03 21:57:17 2009 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Fri Apr 03 21:57:17 2009 Local Options hash (VER=V4): '504e774e'
Fri Apr 03 21:57:17 2009 Expected Remote Options hash (VER=V4): '14168603'
Fri Apr 03 21:57:17 2009 Socket Buffers: R=[8192->8192] S=[8192->8192]
Fri Apr 03 21:57:17 2009 UDPv4 link local: [undef]
Fri Apr 03 21:57:17 2009 UDPv4 link remote: 64.182.119.51:143
Fri Apr 03 21:57:18 2009 TLS: Initial packet from 64.182.119.51:143, sid=01dbcabc 520a8a5f
Fri Apr 03 21:57:20 2009 VERIFY OK: depth=1, /C=US/ST=CA/L=SanFrancisco/O=Erights-dot-Net/CN=erights.net/[email protected]
Fri Apr 03 21:57:20 2009 VERIFY OK: nsCertType=SERVER
Fri Apr 03 21:57:20 2009 VERIFY OK: depth=0, /C=US/ST=CA/L=SanFrancisco/O=Erights-dot-Net/CN=erights.net/[email protected]
Fri Apr 03 21:57:21 2009 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Apr 03 21:57:21 2009 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Apr 03 21:57:21 2009 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Fri Apr 03 21:57:21 2009 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Apr 03 21:57:21 2009 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Fri Apr 03 21:57:21 2009 [erights.net] Peer Connection Initiated with 64.182.119.51:143
Fri Apr 03 21:57:22 2009 SENT CONTROL [erights.net]: 'PUSH_REQUEST' (status=1)
Fri Apr 03 21:57:23 2009 PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 64.182.119.41,dhcp-option DNS 216.221.162.106,dhcp-option DNS 216.221.160.10,route 172.28.0.1,topology net30,ping 10,ping-restart 120,ifconfig 172.28.1.238 172.28.1.237'
Fri Apr 03 21:57:23 2009 OPTIONS IMPORT: timers and/or timeouts modified
Fri Apr 03 21:57:23 2009 OPTIONS IMPORT: --ifconfig/up options modified
Fri Apr 03 21:57:23 2009 OPTIONS IMPORT: route options modified
Fri Apr 03 21:57:23 2009 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Fri Apr 03 21:57:23 2009 There are no TAP-Win32 adapters on this system.  You should be able to create a TAP-Win32 adapter by going to Start -> All Programs -> OpenVPN -> Add a new TAP-Win32 virtual ethernet adapter.
Fri Apr 03 21:57:23 2009 Exiting
自由门,TOR,在线代理,随便你怎样都可以穿。
谢谢各位前辈
